"Structural Beam Analysis" plugin error
"Structural Beam Analysis" plugin error - Index outside matrix boundaries error - Сообщения
#21 Опубликовано: 05.02.2020 09:29:37
120 сообщений из 337 понравились пользователям.
the plugin now works thanks to Andrey . Unfortunately the diagrams are made exclusively in imperial units; this greatly limits the use and, if I understand correctly, the author has not expressed his intention to continue the maintenance .
#22 Опубликовано: 05.02.2020 12:13:40
Such a joke ! Like the Congress that has not yet defined pi [3 or 4].
#23 Опубликовано: 16.09.2022 08:59:03
Safak
Safak
Hi everyone,
I have been using Smath for many years, but this is my first time writing to the forum
I have a problem with Structural Beam Analysis plugin. I download the Beam Analysis Input Guide from Extansions Manager and didn't change anything in the Smath file.
I couldn't figure out what is causing this situation. Do you have any idea?
Thanks in advance,
#24 Опубликовано: 16.09.2022 10:03:41
churichuro
churichuro
28 сообщений из 79 понравились пользователям.
work fine for me, maybe -->
This worksheet requires that the associated Plugin (Structural Beam Analysis
Utility Functions by Redem Legaspi Jr.) be downloaded and enabled from SMath
Studio Extension Manager tool.
#25 Опубликовано: 16.09.2022 10:24:58
Safak
Safak
Thank you for your reply. The plugin was already enabled.
#26 Опубликовано: 16.09.2022 12:20:28
churichuro
churichuro
It's like there's a missing data
#27 Опубликовано: 03.01.2023 14:56:24
oli123
oli123
Hello.
Sources of Beam Analysis Utility Functions stored on SMath server but author of a plug-in asked not to share them.
Several days ago I've got permissions to fix an issue.
Could somebody help me with that?
Plug-in functionality restored now. Tested ok with all available sample worksheets.
New version of a plug-in available using Extensions Manager.
Hi Andrey,
is this plugin source still not shareable? I wanted to modify some of the plotting for my use, such as showing on plot SI units or no unit at all.
#28 Опубликовано: 04.01.2023 07:10:05
1 534 сообщений из 1 850 понравились пользователям.
You can use dotPeek to decompile c# assembly (BeamAnalysisUtilityFunctions.dll). Based on these sources, you can write your own plugin. It will be difficult, but you will be able to realize your ideas.
