UPDATED: SMath Studio 0.98.6047 (22 July 2016)
UPDATED: SMath Studio 0.98.6047 (22 July 2016) - Messages
#1 Posted: 7/21/2016 9:00:40 PM
2273 likes in 3737 posts.
SMath Studio 0.98.6047 available
Latest changes (against SMath Studio 0.98.5997)
  • Updating of Scrollbar Bookmarks fixed on region Delete and Undo/Redo operations;
  • Performance significantly increased when opening worksheets (invisible Regions do not call for invalidation of the worksheet anymore);
  • SS-2325: Scrollbars related multithreading issue appeared sometimes when working with scrollbars fixed;
  • Initial implementation of the built-in debugging tools completed (set breakpoint [Ctrl+F8 or context menu] and recalculate a worksheet);
  • Pause button is available on main toolbar now - it allows to pause calculation and see an exact place where calculation is in progress;
  • Plug-in name included into the Tooltip for functions/variables/operators;
  • Arctan2() function implemented (see known issues below).
Updated 22 July:
  • All breakpoints shown on the vertical scrollbar now, even if they are all in the same region;
  • Issue regarding plug-ins back-compatibility related to debugging fixed;
  • Context Menu with Copy button implemented for the list in Watch panel;
  • Fixed issue when unwanted selection appeared sometimes on debugging;
  • Errors appeared during calculation immediately displayed on vertical Scrollbar now.
Updated 24 July:
  • Tooltips implemented for items in Watch panel;
  • Calculation logic improved for better support of existing worksheets created by previous SMath Studio versions;
  • Critical issue fixed appears on opening Dynamic Assistance list without any Evaluable Region before the cursor;
  • Plug-ins related back-compatibility issue fixed.
Known issues
  • Debugging: Hotkeys for debugging not assigned yet (except Ctrl+F8 for toggling breakpoints);
  • Debugging: Breakpoints set on numbers may not work;
  • Calculation: Function atan(2) has couple of issues;
  • Backcompatibility: Some of the worksheets will not be correctly recalculated still (issue related to undefined variables in definitions).
  • Interface translation: Some strings is not translated yet (they even not registered in translation service).
Download
9 users liked this post
NDTM Amarasekera 7/22/2016 1:51:00 AM, Radovan Omorjan 7/22/2016 3:29:00 AM, sergio 7/22/2016 5:29:00 AM, Igor Skarine 7/23/2016 7:17:00 PM, Mike Kaganski 7/22/2016 5:39:00 AM, Davide Carpi 7/22/2016 5:51:00 AM, Peter 7/22/2016 7:01:00 AM, frapuano 7/22/2016 7:59:00 AM, уни 7/21/2016 11:50:00 PM
#2 Posted: 7/22/2016 3:01:31 PM
Updated with new links to the corrected build (plug-ins back-compatibility fixed).
4 users liked this post
sergio 7/22/2016 5:28:00 PM, NDTM Amarasekera 7/22/2016 11:18:00 PM, уни 7/23/2016 2:40:00 AM, Davide Carpi 7/23/2016 4:44:00 AM
#3 Posted: 7/24/2016 8:06:23 PM
Updated with new links to the corrected build. Plug-ins back-compatibility fixed: http://en.smath.info/forum/yaf_postst7662_Error--Unable-to-import-XLSX-data-file-in-SS-98-6047.aspx
3 users liked this post
NDTM Amarasekera 7/24/2016 10:59:00 PM, Вячеслав Мезенцев 7/25/2016 1:15:00 AM, Davide Carpi 7/25/2016 4:31:00 AM
#4 Posted: 8/1/2017 8:09:01 PM
983 likes in 6866 posts.
If I would like to upload a worksheet, how this can be done?.
Example: in the conference "Questions" click on "New topic"
that will bring the line menu up there,
click on "trombone symbol" ... upload a new file,
double click in the work sheet in your system.
Finally, click on "Upload", then "Post" below.
You can proceed same way in any of the conference [Samples, Bugs ...]
Cheers, Jean
