Crash smathstudio 7251 on Ubuntu
Crash smathstudio 7251 on Ubuntu - Сообщения
#1 Опубликовано: 10.11.2019 06:54:22
philippe dalet
philippe dalet
18 сообщений из 34 понравились пользователям.
Hello Andrey
I launch smathstudio 7251 on Ubuntu 16.04 and 18.04 (64 bits): It crashes.
mono version used: Mono JIT compiler version 6.4.0.198 (tarball Tue Sep 24 01:20:30 UTC 2019)
Before 7250, it ran well.
Philippe
administrateur@HP-ProBook-6570b:~/Téléchargements/SMathStudioDesktop.0_99_7251.Mono$ ./smathstudio_desktop_mono
- [AppDir] SpecialFunctions 1.12.7251.32800 (12 ms.)
- [AppDir] XMCDFileType 1.12.7251.32800 (2 ms.)
- [AppDir] StandardToolboxButtons 1.1.7251.32800 (0 ms.)
- [AppDir] TextRegion 1.11.7251.32800 (5 ms.)
- [AppDir] HTMLFileType 1.14.7251.32800 (1 ms.)
- [AppDir] PictureRegion 1.10.7251.32800 (1 ms.)
- [AppDir] PlotRegion 1.11.7251.32800 (5 ms.)
- [AppDir] SMath Viewer Files Plugin 1.1.7251.32841 (1 ms.)
- [AppDir] ImageFileType 1.11.7251.32800 (0 ms.)
- [AppDir] SMathFileType 1.11.7251.32800 (0 ms.)
Unhandled Exception:
System.EntryPointNotFoundException: GetKeyboardState assembly: type: membernull)
at (wrapper managed-to-native) ..(byte[])
at .. (System.Windows.Forms.Keys ) [0x0000b] in <8798750fc7d24db088010d856e23bb95>:0
at .. (System.Text.RegularExpressions.Match ) [0x00020] in <8798750fc7d24db088010d856e23bb95>:0
at System.Text.RegularExpressions.Regex.Replace (System.Text.RegularExpressions.MatchEvaluator evaluator, System.Text.RegularExpressions.Regex regex, System.String input, System.Int32 count, System.Int32 startat) [0x00094] in <2703bbaa0a6e4686b6033c2dddb1a363>:0
at System.Text.RegularExpressions.Regex.Replace (System.String input, System.Text.RegularExpressions.MatchEvaluator evaluator, System.Int32 count, System.Int32 startat) [0x0000e] in <2703bbaa0a6e4686b6033c2dddb1a363>:0
at System.Text.RegularExpressions.Regex.Replace (System.String input, System.Text.RegularExpressions.MatchEvaluator evaluator) [0x00023] in <2703bbaa0a6e4686b6033c2dddb1a363>:0
at System.Text.RegularExpressions.Regex.Replace (System.String input, System.String pattern, System.Text.RegularExpressions.MatchEvaluator evaluator, System.Text.RegularExpressions.RegexOptions options, System.TimeSpan matchTimeout) [0x0000a] in <2703bbaa0a6e4686b6033c2dddb1a363>:0
at System.Text.RegularExpressions.Regex.Replace (System.String input, System.String pattern, System.Text.RegularExpressions.MatchEvaluator evaluator) [0x00000] in <2703bbaa0a6e4686b6033c2dddb1a363>:0
at .. (System.Collections.Generic.IList`1[T] ) [0x000a1] in <8798750fc7d24db088010d856e23bb95>:0
at .. () [0x000a8] in <8798750fc7d24db088010d856e23bb95>:0
at .. () [0x0075b] in <8798750fc7d24db088010d856e23bb95>:0
at ...ctor (SMath.Manager.SessionProfile ) [0x0020d] in <8798750fc7d24db088010d856e23bb95>:0
at (wrapper remoting-invoke-with-check) ...ctor(SMath.Manager.SessionProfile)
at SMath.UI.Desktop.MainForm. (System.Object , System.EventArgs ) [0x00285] in <8798750fc7d24db088010d856e23bb95>:0
at SMath.UI.Desktop.MainForm. () [0x005b0] in <8798750fc7d24db088010d856e23bb95>:0
at SMath.UI.Desktop.MainForm..ctor (System.Collections.Generic.List`1[T] , System.Boolean ) [0x0061a] in <8798750fc7d24db088010d856e23bb95>:0
at (wrapper remoting-invoke-with-check) SMath.UI.Desktop.MainForm..ctor(System.Collections.Generic.List`1,bool)
at SMath.UI.Desktop.Program. (System.String[] ) [0x0009a] in <8798750fc7d24db088010d856e23bb95>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.EntryPointNotFoundException: GetKeyboardState assembly: type: membernull)
#2 Опубликовано: 13.11.2019 19:21:34
That one is for Andrey, however ...
What I know from experience is about a new version of some software.
Before installing a new version of "JoBo" software,
you must evaporate previous "JoBlo" from the PC.
Evaporation is via regedit to access Windows registry.
From there, you delete all items "JoBlo, not always easy
to recognize unless identified otherwise by supplier.
Remove program from other Windows does not evaporate,
it just deactivate ...
The question is: were is the Smath evaporation procedure ?
Sorry, can't help more.
#3 Опубликовано: 26.01.2020 14:13:07
1226 сообщений из 2151 понравились пользователям.
I confirm the problem with 7251 on Kubuntu 19.10 with fresh mono-complete package.
EDIT: 7030 works.Just trying the plugins...
Показать спойлер
#4 Опубликовано: 26.01.2020 18:46:51
That's the right answer: 7030 is the latest stable version.
There are few other stable versions ... 6179 typical glorious !
What is not tutored is how to evaporate an existing version.
i.e: render PC virgin of Smath like it had never existed,
install latest stable 7030
Just comments ... back to work.
#5 Опубликовано: 14.09.2020 18:52:21
Fixed. Ref. https://smath.com/bts/Issues/IssueDetail.aspx?id=4642
#6 Опубликовано: 15.09.2020 04:08:21
miro
miro
Hello
How can I get the fixed version?
#7 Опубликовано: 17.09.2020 16:54:39
Anders or Eric
Anders or Eric
4 сообщений из 40 понравились пользователям.
Yes please, I'm looking forward to it as well, thanks--
#8 Опубликовано: 18.09.2020 13:56:37
Arie
Arie
93 сообщений из 285 понравились пользователям.
Did you try the latest stable release? https://smath.com/file/vg27Q/SMathStudioDesktop.0_99_7561.Mono.tar.gz
#9 Опубликовано: 18.09.2020 14:56:06
Anders or Eric
Anders or Eric
Yes, it crashes after the splash screen. Here's some of my info:
OS is Kubuntu 18.04
Mono version info:
~$ mono --version
Mono JIT compiler version 6.12.0.90 (tarball Fri Sep  4 14:01:23 UTC 2020)
Copyright (C) 2002-2014 Novell, Inc, Xamarin Inc and Contributors. www.mono-project.com
        TLS:           __thread
        SIGSEGV:       altstack
        Notifications: epoll
        Architecture:  amd64
        Disabled:      none
        Misc:          softdebug
        Interpreter:   yes
        LLVM:          yes(610)
        Suspend:       hybrid
        GC:            sgen (concurrent by default)
Terminal output from attempt to run SMath:
~/SMathStudioDesktop.0_99_7561.Mono$ ./smathstudio_desktop_mono
(mono:15774): Gtk-WARNING **: 12:45:22.270: Unable to locate theme engine in module_path: "adwaita",
(mono:15774): Gtk-WARNING **: 12:45:22.275: Unable to locate theme engine in module_path: "adwaita",
- [AppDir] SpecialFunctions 1.12.7561.40250 (3 ms.)
- [UserDir] Conditionally Formatted Label 1.0.7480.25296 (2 ms.)
- [UserDir] RadioButtonList Region 1.0.7480.25320 (2 ms.)
- [UserDir] Data Exchange 1.1.6858.3747 (7 ms.)
- [UserDir] Table Region 0.3.7557.19317 (2 ms.)
- [AppDir] SMathFileType 1.11.7561.40250 (0 ms.)
- [AppDir] ViewerFileType 1.1.7561.40250 (0 ms.)
- [AppDir] StandardToolboxButtons 1.1.7561.40250 (1 ms.)
- [AppDir] PlotRegion 1.11.7561.40250 (2 ms.)
- [AppDir] HTMLFileType 1.14.7561.40250 (0 ms.)
- [AppDir] XMCDFileType 1.12.7561.40250 (1 ms.)
- [AppDir] PictureRegion 1.10.7561.40250 (1 ms.)
- [AppDir] TextRegion 1.11.7561.40250 (1 ms.)
- [AppDir] ImageFileType 1.11.7561.40250 (0 ms.)
System.EntryPointNotFoundException: GetKeyboardState assembly:<unknown assembly> type:<unknown type> membernull)
  at .. (System.Windows.Forms.Keys ) [0x0000b] in <96ec79978efd4109963dd12019ab1382>:0
  at .. (System.Text.RegularExpressions.Match ) [0x00020] in <96ec79978efd4109963dd12019ab1382>:0
  at System.Text.RegularExpressions.Regex.Replace (System.Text.RegularExpressions.MatchEvaluator evaluator, System.Text.RegularExpressions.Regex regex, System.String input, System.Int32 count, System.Int32 startat) [0x00094] in <3d97dda773a54430b892e1d794e5d921>:0
  at System.Text.RegularExpressions.Regex.Replace (System.String input, System.Text.RegularExpressions.MatchEvaluator evaluator, System.Int32 count, System.Int32 startat) [0x0000e] in <3d97dda773a54430b892e1d794e5d921>:0
  at System.Text.RegularExpressions.Regex.Replace (System.String input, System.Text.RegularExpressions.MatchEvaluator evaluator) [0x00023] in <3d97dda773a54430b892e1d794e5d921>:0
  at System.Text.RegularExpressions.Regex.Replace (System.String input, System.String pattern, System.Text.RegularExpressions.MatchEvaluator evaluator, System.Text.RegularExpressions.RegexOptions options, System.TimeSpan matchTimeout) [0x0000a] in <3d97dda773a54430b892e1d794e5d921>:0
  at System.Text.RegularExpressions.Regex.Replace (System.String input, System.String pattern, System.Text.RegularExpressions.MatchEvaluator evaluator) [0x00000] in <3d97dda773a54430b892e1d794e5d921>:0
  at .. (System.Collections.Generic.IList`1[T] ) [0x000a1] in <96ec79978efd4109963dd12019ab1382>:0
  at .. () [0x000a8] in <96ec79978efd4109963dd12019ab1382>:0
  at .. () [0x0075b] in <96ec79978efd4109963dd12019ab1382>:0
  at ...ctor (SMath.Manager.SessionProfile ) [0x0020d] in <96ec79978efd4109963dd12019ab1382>:0
  at SMath.UI.Desktop.MainForm. (System.Object , System.EventArgs ) [0x00285] in <96ec79978efd4109963dd12019ab1382>:0
  at SMath.UI.Desktop.MainForm. () [0x005b0] in <96ec79978efd4109963dd12019ab1382>:0
  at SMath.UI.Desktop.MainForm..ctor (System.Collections.Generic.List`1[T] , System.Boolean ) [0x0061a] in <96ec79978efd4109963dd12019ab1382>:0
  at (wrapper remoting-invoke-with-check) SMath.UI.Desktop.MainForm..ctor(System.Collections.Generic.List`1<string>,bool)
  at SMath.UI.Desktop.Program. (System.String[] ) [0x0009a] in <96ec79978efd4109963dd12019ab1382>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.EntryPointNotFoundException: GetKeyboardState assembly:<unknown assembly> type:<unknown type> membernull)
#10 Опубликовано: 24.09.2020 00:42:00
Anders or Eric
Anders or Eric
Hi, I'm curious- is anyone out there successfully running the mono version of 7561 on any flavor of linux?
#11 Опубликовано: 24.09.2020 19:25:12
tomracing
tomracing
8 сообщений из 16 понравились пользователям.
Nope, stuck on 7030 waiting for the patched version to come out.
#12 Опубликовано: 01.10.2020 16:12:08
tomracing
tomracing
new version just out 0.99.7579 includes the patch and works on Arch.
#13 Опубликовано: 01.10.2020 17:55:07
Ruben Sidranski
Ruben Sidranski
Check your tool bar! Missing items on Linux Mint 20. I just posted on the 0.99.7579 thread...
But yes, it will now run on Linux
#14 Опубликовано: 02.10.2020 09:55:20
tomracing
tomracing
@ElSid
tool bar is fine in Arch
Цитата
Mono --version
Mono JIT compiler version 6.10.0 (makepkg/5d03a6fe116 Wed 15 Jul 2020 03:01:56 PM -03)
TLS: __thread
SIGSEGV: altstack
Architecture: amd64
Disabled: none
Misc: softdebug
Interpreter: yes
LLVM: supported, not enabled.
Suspend: hybrid
