Document mode
Document mode - Сообщения
#21 Опубликовано: 10.01.2021 19:58:17
Issues found in previous nightly build fixed + minor improvements added.
Beta updated: https://en.smath.com/forum/yaf_postst20094_Beta--SMath-Studio-0-99-7681--11-January-2021.aspx
  • Creating of new Regions using Insert menu in Document mode fixed;
  • Automatic replacement improved for MathRegions;
  • Changing text formatting now affects on children Regions in the selected range;
  • TextRegion: Text selection rendering improved;
  • Children Regions rendering improved;
  • Fixed critical errors happened sometimes on file open.
sergio 13.01.2021 11:43:00
#22 Опубликовано: 13.01.2021 10:29:05
Ruben Sidranski
Ruben Sidranski
Andrei
I'm assuming that the document mode is accessed via the button on the lower right next to the zoom spyglass. When I hover over it, Windows 10 as I never got the fonts fixed in Linux, it blinks like crazy and it's hard to select.
In addition, I ran into an issue trying to upsave some old files. I updated the font to Calibri and now the text in the descriptions do not match. New variables are using calibri and old variables that I carried over are still in Ariel
#23 Опубликовано: 13.01.2021 11:55:20
... as I never got the fonts fixed in Linux...
This font issues bothers me much too on Linux. Bold and italic characters doesn't show on worksheets.
They appear as normal font characters. I have mentioned about this problematic issue before.
#24 Опубликовано: 13.01.2021 11:56:53
EISid,
to activate the 'document' mode follow the instructions contained in the first post of this discussion.
That unstable button at the bottom right (it is unstable even in win10) is used for pagination but not in 'document' mode.
#25 Опубликовано: 13.01.2021 20:11:27
No. Quoting an instruction here from my first post:
Here is an instruction about how one can make Document mode enabled:
  1. Open Tools > Plugins..., find and select Text Region, set Document mode checkbox checked:
  2. Find a New document item in File menu:
Thank you. Fixed now in the latest nightly build.
It was decided to show all descriptions using monospace font with no regards to what font is set as default for the document. This was implemented few Months ago.
#26 Опубликовано: 13.01.2021 20:58:46
Ruben Sidranski
Ruben Sidranski
Is it possible to make the descriptions and the "Area" descriptors uniform? Monospace font is fine, consistency would be appreciated. Calculations look due to different text fonts. INTERPOLATION is a new area.
I'm surprised this has not been seen by others as I've been in-communicato for a while.
Thanks for fixing the blinking annoyance on the new build!
#27 Опубликовано: 13.01.2021 21:57:24
Prepared a short demo:
overlord 13.01.2021 22:54:00
#28 Опубликовано: 20.01.2021 20:57:00
Important improvements in todays update: https://en.smath.com/forum/yaf_postst20114_Beta--SMath-Studio-0-99-7691--21-January-2021.aspx
Search in text significantly improved:
Invisible symbols can be shown:
Automatic replacement can be disabled:
+ work with ordered/unordered lists significantly improved.
IVR 22.01.2021 03:57:00
#29 Опубликовано: 12.05.2021 20:44:16
Copy from Worksheet to Document finally implemented:
It is also possible now to paste images from Clipboard directly to Text.
Of course it works in both cases: for Worksheet and Document modes.
churichuro 12.05.2021 23:56:00, Oscar Campo 13.09.2021 13:09:00
#30 Опубликовано: 07.09.2021 18:51:38
Finally, SMath Studio splitted to two different applications: SMath Solver and SMath Writer.
SMath Solver
This is a new name to what was previously called SMath Studio. This application allows user to be focused on calculations.
SMath Writer
Created for work with rich text which includes math. Has Ribbon menu built-in and interface tuned for best experience in documentation and text formatting.
SMath Studio
This is a name which gathers Solver and Writer in a single package.
Both applications supports their own file formats: Solver - *.sm, Writer - *.smw. If you have created Documents in SMath Studio using previous program versions please just change an extension manually.
Today I've release beta version of SMath Studio package which contains Solver/Writer inside - https://en.smath.com/forum/yaf_postst21450_Beta--SMath-Studio-0-99-7921--08-September-2021.aspx
Please note: Solver has no any significant changes, so one can continue using it in production, but Writer is an alpha version of what I've started to work on. Writer requires more time from me to be polished to have all the same features as currently available in Solver.
Let me know what you think.
Best regards, Andrey Ivashov.
Serg 26.09.2021 15:11:00, sergio 08.09.2021 04:29:00, IVR 12.09.2021 05:26:00
#31 Опубликовано: 23.11.2021 05:31:24
Glenn Thierens
Glenn Thierens
A very nice feature, thanks alot!
#32 Опубликовано: 23.11.2021 12:57:43
churichuro
churichuro
29 сообщений из 79 понравились пользователям.
New Release soon, please!
