Some plugins installation fail
Some plugins installation fail - Maxima, Excel Files, Script Region and muMath Files plugins installation don't work - Сообщения
#1 Опубликовано: 10.06.2021 03:47:53
Ibrahima Fall
Ibrahima Fall
0 сообщений из 11 понравились пользователям.
Hi all!
I have problem when I try to install the following plugs:
Excel Files plugins
MaximaPlugin
Script Region
muMath Files plugin
I get this message: "Plug-in(s) installation failed"
All plugins are working fine except these four that I mentioned.
I am under Windows 10 pro. I use maxima-5.45.0 and Office 365.
Any help would be welcome.
#2 Опубликовано: 10.06.2021 16:12:32
1225 сообщений из 2151 понравились пользователям.
Confirmed for Maximaplugin with a new portable version 7822.
However, automatic upgrade of an installed version with Maximaplugin to 7822 works. Maximaplugin remains functional.
Didn't test with Maxima 5.45 though, but the problem is before you even can specify the path to Maxima.
#3 Опубликовано: 10.06.2021 19:35:46
Maxima plug-in corrected.
Please update it using Extensions Manager.
#4 Опубликовано: 10.06.2021 20:48:20
Ibrahima Fall
Ibrahima Fall
Thank you Andrei for the updates.
Now Maxima, Excel Files and muMath Files plugins work fine.
Only Script Region plugin don't work.
#5 Опубликовано: 12.06.2021 04:35:52
Script region rebuilt and can be installed to the latest SMath Studio version again.
Thanks.
#6 Опубликовано: 12.06.2021 06:51:02
Ibrahima Fall
Ibrahima Fall
Thumb up Andrei.
